Page 1 of 2
Best LED rear brake light?
Posted: Sun Sep 18, 2016 7:41 pm
by alanscottj
Who does the best LED rear brake light?
Many thanks.
Scott
Re: Best LED rear brake light?
Posted: Sun Sep 18, 2016 7:45 pm
by garry inglis
holty on here he makes and sells them ive one on both my scoots fit and work perfect £20
Posted: Sun Sep 18, 2016 7:52 pm
by holty
ha, i just put a reply on your other post.
Posted: Sun Sep 18, 2016 8:04 pm
by Scooterdude
Don't be tempted to just get a led replacement bulb, they are very dim I ended up putting my normal bulb back in!
Posted: Sun Sep 18, 2016 8:07 pm
by alanscottj
Cheers troops!
Posted: Sun Sep 18, 2016 8:52 pm
by rainbowrunner
just fitted a BGM led unit, bright as hell, well chuffed.
Posted: Sun Sep 18, 2016 9:58 pm
by immylam
Had a couple of the BGM ones and they are pretty good .....for the 6 months they work....
Posted: Sun Sep 18, 2016 10:01 pm
by alanscottj
Ordered one from Holty
Posted: Sun Sep 18, 2016 10:12 pm
by HxPaul
Just for a bit of balance,I have used an LED bulb in the rear of my series 3 for over a year and it is not dim but quite bright,the best part about it is that when I use the back brake the lights dont almost go off,but stay bright.
Posted: Sun Sep 18, 2016 10:31 pm
by Scooterdude
HxPaul wrote:Just for a bit of balance,I have used an LED bulb in the rear of my series 3 for over a year and it is not dim but quite bright,the best part about it is that when I use the back brake the lights dont almost go off,but stay bright.
Is yours the full DC system with battery? Mine is AC no battery and I'm using a 55watt halagen front bulb which is very bright, but as you say when you brake even with the led back bulb the front light almost dies.
I read somewhere those led back light units must be used only with DC current ?
