12v bench power supply
Posted: Sun Sep 18, 2016 12:50 pm
by diesel
Can any of the electrical guru's recommend a suitable power source for testing the electrics on the scooter instead of starting it up and gassing myself in the shed?
Re: 12v bench power supply
Posted: Sun Sep 18, 2016 1:05 pm
by coaster
I d use either a small alarm type battery, a car battery or a car battery charger if mains power is available. Just make sure you connect an in line fuse to your test lead, 5 amp should do it 8-)
Posted: Sun Sep 18, 2016 1:15 pm
by Padge
as above, small 12v alarm battery or car battery, 5-10 amp inline "blade" fuse, connect earth to scooter frame and positive to 12v supply on loom (disconnect from regulator first) only thing that wont work is a 12 AC horn, but you will get a "click" when you press the button when it's wired up right
Posted: Sun Sep 18, 2016 1:53 pm
by Morgan
I've used one of the ac 230v-12v lighting transformers (under £4 from Toolstation, probably cheaper if you get it off the internet). Gives you ac so will also test if your rectifier is working (if you're using dc).
Posted: Sun Sep 18, 2016 2:05 pm
by diesel
Thanks for the speedy replies Lads
Posted: Sun Sep 18, 2016 2:30 pm
by diesel
http://www.argos.ie/static/Product/part ... 418754.htm
Could I connect one of these to the scoot (negative to frame and positive to loom)? or am I being stupid?
Posted: Sun Sep 18, 2016 4:27 pm
by coaster
diesel wrote:http://www.argos.ie/static/Product/part ... 418754.htm
It MIGHT work diesel but automatic chargers often need a load in order for them to output any voltage. Simple charger will work but might not have enough capacity to power a headlamp. Personally I'd go for a 12v 7 Amp ph alarm battery although you will still need the means to charge it from time to time
Posted: Sun Sep 18, 2016 4:49 pm
by diesel
Alarm battery it is, cheers
Posted: Mon Sep 19, 2016 9:23 am
by EddieStone
Fit an inline fuse in the positive lead of the battery.
Posted: Mon Sep 19, 2016 1:32 pm
by diesel
EddieStone wrote:Fit an inline fuse in the positive lead of the battery.
Already done. Cheers
