R1/R6 shocker?
Posted: Wed Sep 14, 2016 2:24 pm
by satans reject
Afternoon folk,
I am looking at buying a R1/R6 rear shocker, whats the difference between the two?
Was it just a rebranding or are they differeent in size, shape etc?
thanks
scott
Re: R1/R6 shocker?
Posted: Wed Sep 14, 2016 5:48 pm
by Scooterdude
I recently looked into it mate. To many ifs and buts, not worth the hastle, you need special bushes or it won't fit, you can only do the nuts up finger tight or it will snap, you need a different spring,
There is one on eBay at the moment for a Lambretta but the gas reservoir runs across ways as opposed to going vertical so that won't fit, best get a Pro-Tech mate.
Re: R1/R6 shocker?
Posted: Wed Sep 14, 2016 6:20 pm
by Boreham
satans reject wrote:Afternoon folk,
thanks
scott
Hi Scott, the R6 is slightly shorter at 295mm, ideal if you need more frame clearance on a reed motor, only go for the early type where the cylinder runs vertical to the body.
As the previous reply you need the bushes to fit a Lambretta (go for the nylon type) plus a softer spring as the Yamaha is extremely heavy compared to a scooter!
It is very simple change and if you speak to Lee 'Chiggy' Chambers he supplies all the bits (his website is lambretta upgrades)
They are very good and do improve the stability.
Martyn
Re: R1/R6 shocker?
Posted: Wed Sep 14, 2016 9:18 pm
by Knowledge
Scooterdude wrote:I recently looked into it mate. To many ifs and buts, not worth the hastle, you need special bushes or it won't fit, you can only do the nuts up finger tight or it will snap, you need a different spring,
yes, you need bushes to fit the Lambtretta. Only use the nylon bushes. You also need slim nyloc nuts. You can tighten them up tight, but you don't need to. If you tighten them up on nylon bushes; the shock won't break. This was only a problem with bronze bushes.
All R1 shocks have a reservoir that runs in line with the shock. Most R6 shocks have the reservoir running perpendicular to the body of the shock.
Re: R1/R6 shocker?
Posted: Fri Sep 16, 2016 11:11 am
by satans reject
thanks for the advice so far gents,
next question....(sorry!).....
how would you know if the shocker has had the correct spring fitted (for a lambretta...)
ive had a look over the one ive recived and theres no obvious markings saying what pound spring is fitted, even though the guy says its the 'right' one :?
thanks again
scott
Re: R1/R6 shocker?
Posted: Fri Sep 16, 2016 12:43 pm
by nellyboyo
Ive got one on my S2 and fitted the spring myself so I know its right. Its set on its lowest I think .
I suppose it`ll be unrideable and rock hard with the R1 spring on. You may do damage to your mounts and your arse if you go mental with it
Re: R1/R6 shocker?
Posted: Fri Sep 16, 2016 12:58 pm
by Fruitjuice
Small issue to look out for with these R1/6 shocks that I noticed:
The 180-200lbs 'Demon Tweaks' replacement springs are a little wider in inner diameter than the original Yamahe spring on the shock, so there is some play between the spring and the upper & bottom spacers where the spring rests. This allowed the spring to rub on my plastic GP rear mudguard and eventually made it crack.
Late Spanish Servetta Lynx/Lince casings and frames have longer shock mounting studs and on these you don't have the issue with the nuts not having eanough thread to be fully tightened.
Re: R1/R6 shocker?
Posted: Fri Sep 16, 2016 6:30 pm
by Boreham
http://www.lambrettaupgrades.co.uk/apps ... e/products
Stocks the correct springs (i use 180lb) plus all the bushes etc......
