Cost of sending an engine?
Posted: Sat Sep 10, 2016 11:27 am
by Timbo
Complete apart from top end. How much for UK and who to use. What's the weight?
Re: Cost of sending an engine?
Posted: Sat Sep 10, 2016 11:46 am
by YAMLAM
also check the cover value if it got lost or damaged, a lot of courier companies have a £100 limit, unless you take added insurance.
Posted: Sat Sep 10, 2016 2:32 pm
by rosscla
Be careful with the likes of Hermes their T&C exclude engines or parts.
Posted: Sat Sep 10, 2016 3:34 pm
by DigDug
rosscla wrote:Be careful with the likes of Hermes their T&C exclude engines or parts.
Don't use My Hermes unless you're not bothered about seeing your engine again.
Posted: Sun Sep 11, 2016 1:12 pm
by purple_pill67
Drain the oil and pack it well
Posted: Mon Sep 12, 2016 10:16 am
by warts
I sent a very heavy valve amplifier, more weight and cost than a lambretta engine.
I found a www which gave you a list of carriers which you could suss out the t&t's, costs, weights and volumes. The weight turned out to be irrelevant, volume was the thing, with a max dimention limit.
All signed for, tracked and treated well. I did take some care with packaging though - made a wooden crate and put in lots of padding.
Came back in same crate.
I'll have a look see if I can find the invoice.
As mentioned clean and drain first.
If you are sending it to a company, have a word with them see if they have any recommendations.
Posted: Mon Sep 12, 2016 1:49 pm
by kennystag
Hi warts,
What company did you use. Do you have the www one you where talking about for a list of couriers.
Stag
Posted: Wed Sep 14, 2016 8:28 am
by warts
I found them through interparcel. I'm away, so the invoice - if I still have - it is not available ATM.
