Page 1 of 2
Spanish series 2
Posted: Thu Sep 08, 2016 5:58 pm
by Daggs
Two questions:
Is it possible to fit the later extended engine silent blocks to a series 2 engine in a SPANISH S2 ?
Has anyone manged to fit front suspension dampers to a SPANISH S2 whilst retaining the turning mudguard ?
Re: Spanish series 2
Posted: Thu Sep 08, 2016 6:04 pm
by Toddy
Daggs wrote:Two questions:
Yes and yes
I fitted Dampers (BGM on Mine quite tight under the mudguard to get on and off but managed :D
Posted: Thu Sep 08, 2016 7:23 pm
by DigDug
As Toddy said.
Spanish casings are no different when it comes to silent blocks.
And the dampers on the turning mudguard, yes me and Eibar managed it on the Winter TV2
They used the clamp on top brackets - Beedspeed do them although I can't see why you couldn't use the welded bracket.
Posted: Thu Sep 08, 2016 8:29 pm
by whonatic
Got welded on brackets on both my eibars
Posted: Thu Sep 08, 2016 8:58 pm
by Daggs
Did you not find the mudguard holding brackets obstructed the weld on damper brackets ?
Posted: Fri Sep 09, 2016 6:04 am
by DigDug
Daggs wrote:Did you not find the mudguard holding brackets obstructed the weld on damper brackets ?
Even the clamp on ones take a bit of fiddling but it is possible.
Posted: Fri Sep 09, 2016 7:56 am
by hendy
I plan to use non adjustable bgm ones or escorts (undecided at the moment) on my Spanish s2. Does anyone know of any particular problems using either of these?
Posted: Fri Sep 09, 2016 8:11 am
by storkfoot
I had those bgm ones on mine. Use the mudguard to trap the nut against the damper mount and screw in from the other side ;-)
Posted: Fri Sep 09, 2016 9:26 am
by Toddy
Bit tight but ok
Posted: Fri Sep 09, 2016 10:07 am
by Daggs
Thanks to all for their input, I'll be giving it a go :D
