Throttle cable reving up!
Posted: Mon Aug 29, 2016 2:46 pm
by Scooterdude
Ok when I rebuilt my LI125 back in the winter I fitted a complete new cable set from Scootopia, anyway I routed everything as per the stickys manual and find the throttle cable slightly on the long side causing a U shaped curve to form just before it reaches the carb.
Now then I can adjust the throttle to tick over nicely but when I sit on the scooter to ride it revs up slightly, not been a problem up until this weekend down at Brighton with my Daughter on the back, it just wants to rev and Rev but as soon as we get off it settles down again, any ideas??
Re: Throttle cable reving up!
Posted: Mon Aug 29, 2016 3:37 pm
by garry inglis
you have got the inner to tight when you sit on the scoot the front of the engine goes down and thats why its reving up and with more weight on the back it will go down a bit more making it even tighter you need to slacken it off abit and maybe get a stronger rear spring
Posted: Mon Aug 29, 2016 3:39 pm
by holty
you should adjust your cable so that it has a little bit of slack in it, when you are sat on it, and your tickover should be set by the tickover screw, not the cable, you should be fine when you have done this.
holty
Posted: Mon Aug 29, 2016 5:03 pm
by Scooterdude
garry inglis wrote:you have got the inner to tight when you sit on the scoot the front of the engine goes down and thats why its reving up and with more weight on the back it will go down a bit more making it even tighter you need to slacken it off abit and maybe get a stronger rear spring
think this is the main problem, just found that the back tyre has almost wore through the engine casing and oil running down the shock so shock must be well f@@ked, in fairness though it is the original one from 1964 so it's has a good innings, I just cleaned it up and painted it during the rebuild to save a few quid shows how carefull you have to be!
Posted: Mon Aug 29, 2016 5:26 pm
by coaster
The cable outer is fixed to the carb and apparently has a 'fair bit of slack so SHOULDN'T make any difference unless you have secured the cable to the fame close to the carb?
