Polini 30mm help
mr series 2
Main scooter: LI 150 Ser 2
https://btcloud.bt.com/web/app/share/invite/nkAHqrWiOvCan anyone please help by telling me if the pipe from the outside of the float bowl on a Polini 30 (thinks same as PWK) goes to the vertical copper pipe at the top of the carb or the horizontal Ali one that's at 90deg on the side of the carb
Thanks in advance for any
ukpeckerwood
Main scooter: Vespa PX210
The one on the top I think is for a vacuum pump feed or a oil feed and should be blanked of.
mr series 2
ukpeckerwood wrote:The one on the top I think is for a vacuum pump feed or a oil feed and should be blanked of.
Thanks for that am I right in thinking the one from the float bowl is just a breather & the one on the side is an overflow
Padge
Main scooter: 1969 Lambretta gp
the one on the float bowl should be the overflow, if you look inside float bowl you will see a copper pipe, (the bit that's a barsteward to get past the floats when you try and fit it to the carb)that goes to the overflow on the bottom
mr series 2
Thanks for both replies it's all become clear now
