float trouble
lammy666
Main scooter: lambretta li 125/190 chop.
has anyone experienced the same problem.
i have a new 28mm and a 30mm phbh dellorto carb and on both carbs my floats have filled up with fuel within a short rideout.
both carbs now need new floats.
the carbs have been sat at the correct angle.
tavspeed
had the same problem,with my phbh 30,with the white type floats,apparently the ethanol in the petrol knacks the glue,and they shouldnt even be supplied in uk carbs,i got a black float from wasp performance at a good price,these are more resistant to the ethanol now used in petrol.
lammy666
cheers for that tavspeed. i will get onto wasp in the morning.
Rich_T
Main scooter: Li Special
Yes, I've seen this several times this year and was given the same story about ethanol etc. Problem is the floats look ultrasonically welded to me not glued. Also, it is possible to quickly repair them with hot water and superglue and....suddenly they don't leak up any more, it is irritating though.
lammy666
is that putting some super glue in hot water then submerging the float in it.
will this not effect the weight
    Users browsing this forum: No registered users and 24 guests
