Page 1 of 2
Two things I learnt today...
Posted: Sat Aug 13, 2016 12:53 pm
by Timbo
How much lighter SIP tubeless wheels are compared to split rims and if you have a leg shield spare wheel carrier and the oil holder then a SIP wheel won't fit because the studs aren't long enough... :roll:
Re: Two things I learnt today...
Posted: Sat Aug 13, 2016 3:01 pm
by Scooterdude
.....and then there's the folks moaning about how hard the tyres are to fit on these rims... Maybe not worth bothering with?
Posted: Sat Aug 13, 2016 3:49 pm
by DigDug
Scooterdude wrote:.....and then there's the folks moaning about how hard the tyres are to fit on these rims... Maybe not worth bothering with?
Do they - my local tyre specialist hasn't complained?
Posted: Sun Aug 14, 2016 10:07 pm
by rosscla
My local one broke their machine and gouged one rim getting scootsmarts on
Posted: Sun Aug 14, 2016 11:54 pm
by Argentopercarter
Timbo wrote: if you have a leg shield spare wheel carrier and the oil holder then a SIP wheel won't fit because the studs aren't long enough... :roll:
Screw one long cylinder head nut to each of the studs on the inside legshield spare wheel carrier and mount the SIP rim using short M8 (13mm spanner size) bolts screwed through the rim into the other end of the long nuts. I find it best to use flat washers under the head of the bolts otherwise they want to chew into the recess in the rim.
Don't know about the oil carrier though.
Posted: Mon Aug 15, 2016 8:51 am
by Timbo
Good thinking will give it a go....
Posted: Mon Aug 15, 2016 4:07 pm
by dennis
Have a word with colin about the long nuts.
Posted: Mon Aug 15, 2016 5:24 pm
by Adam_Winstone
Ditto
Posted: Mon Aug 15, 2016 6:36 pm
by rosscla
You'll buy threaded hex cheaper on eBay than buying them as long cylinder head nuts with LAT.
https://www.ebay.co.uk/itm/121910012864
Posted: Mon Aug 15, 2016 9:05 pm
by YAMLAM
why wait for the postman, get down to Toolstation :-http://www.toolstation.com/shop/p86819?table=no
