Franspeed advice needed
Posted: Sat Aug 06, 2016 2:19 pm
by Scooterdude
Does anyone know if a franspeed JL 3 will fit on to a series 3 without cutting the rear running board? Also the can looks quite near the side panel, will I be able to remove and replace the panel without taking the can off? Seems a ball ache if I have to each time..
Re: Franspeed advice needed
Posted: Sat Aug 06, 2016 2:39 pm
by 10 inch Terror
On his website it says the rear runner MAY need trimming depending on what rear shock you have fitted. I ran one with short running boards so I can't comment re cutting the runners. I can tell you though that the panels can be removed with the end can fitted no problems at all.
Posted: Sat Aug 06, 2016 2:59 pm
by Scooterdude
Cheers for that. So reading between the lines MAY means they definitely will need cutting. Ok so if I fit short runners what happens to the dog leg brackets? Obviously one side can be removed but I don't fancy chopping the other one off, or for that matter leaving it sticking out on its own.
Posted: Sat Aug 06, 2016 6:18 pm
by fritz
hi scooterdude I,ve got one on a series 3 and did not need to cut footboard
standard length shock and I don't ride 2 up
hope this helps
steve
Posted: Sat Aug 06, 2016 6:43 pm
by Scooterdude
Cheers Steve.
