Franspeed advice needed
Scooterdude
Does anyone know if a franspeed JL 3 will fit on to a series 3 without cutting the rear running board? Also the can looks quite near the side panel, will I be able to remove and replace the panel without taking the can off? Seems a ball ache if I have to each time..
10 inch Terror
Xbox live gamer tag: No.
On his website it says the rear runner MAY need trimming depending on what rear shock you have fitted. I ran one with short running boards so I can't comment re cutting the runners. I can tell you though that the panels can be removed with the end can fitted no problems at all.
Scooterdude
Cheers for that. So reading between the lines MAY means they definitely will need cutting. Ok so if I fit short runners what happens to the dog leg brackets? Obviously one side can be removed but I don't fancy chopping the other one off, or for that matter leaving it sticking out on its own.
fritz
hi scooterdude I,ve got one on a series 3 and did not need to cut footboard
standard length shock and I don't ride 2 up
hope this helps
steve
Scooterdude
Cheers Steve.
