Fork stem
Posted: Thu Jul 28, 2016 5:58 pm
by lee76
Fitting GP forks, leg shields etc to a series 3 non chrome ring Li frame. Where is the best place to cut the frame stem? was going to cut 20 odd mm out of the middle then fit an internal sleeve and weld.
Re: Fork stem
Posted: Thu Jul 28, 2016 10:35 pm
by Knowledge
Knock out the top bearing race and look inside the top of the tube. You will find that this was machined to take the race before the tube was welded to the rest of the frame.
If you just cut 20-odd mm off the top of the steering tube, you will cut off this recess for the race, and the race won't fit any more. Oops.
There are a couple of ways around this:
1. Cut the tube lower down and remove a 20-odd mm section and weld it back together again (some risk of not getting it back on straight)
2. Cut the tube at the top, and use a chrome ring bearing race (smaller OD) and machine-up a spacer to take-up the difference between the tube ID and the bearing race OD.
I am planning this conversion too, and I will be taking option 2, as this worked for me previously.
I hope this is helpful
