Indian Vijay/GP 150 carb manifold
kevspeed
A bit of a problem with an Indian manufactured 150.
At some stage the originally fitted 'Mikarb' and inlet manifold has been removed,and an Italian GP 150 inlet fitted along with a 'Jetex' 22mm carb.
With this existing set up the inlet manifold sits too close to the engine mount,causing the carb to be fitted on an odd angle.
I assume the barrel studs are positioned differently to the barrels meant for the original style Dellorto/Spaco/Jetex carbs and manifolds.
Anybody got an easy fix for this problem?
lambro
Get a remade 150 manifold from Scootopia, fitted a few now and they clear the big engine mounts no problem,
The Indian one you have seem to only fit with the small engine mounts.
Shaun.
kevspeed
The original Indian one has been replaced with a genuine Italian item but the problem persists. Is the remade Scootopia manifold different to the genuine Italian manifold?
    Users browsing this forum: Semrush [Bot] and 24 guests
