Page 1 of 2
Cursed
Posted: Wed Jul 27, 2016 4:02 pm
by Snails
I've had a few scooter related problems of late, the latest one is that my scoot wont start when the exhaust is on
Its a new AF Reverse Cone. It appears to go something like this
1. scooter wont start,
2. take exhaust box off
3. kick scooter over - it starts after a few kicks.
4. turn off
5. refit exhaust
6. start scooter, runs fine. :D
7 turn scooter off or it dies for some reason
9. try to start scoot, but wont start :(
8. go back to step 1.
I had a problem with the carb dropping fuel into the pipe but that appears to be resolved now as now when I take the pipe off there's no fuel in it.
Re: Cursed
Posted: Wed Jul 27, 2016 4:37 pm
by holty
is there something blocking the exhaust, maybe some packing material inside, can you blow through it easy ?
Re: Cursed
Posted: Wed Jul 27, 2016 5:44 pm
by Monty
Here we go again Ed
Has the pipe got any blockages ? Can you blow through it, heavy back preasure will kill it. Any rattles, baffle dropped out blocking the outlet
Carb, bellows on or not, tipping it over to work on the pipe may be leaving fuel in the bellows, heavy spit back same
Then has it run ok on this carb box combination before.
Re: Cursed
Posted: Wed Jul 27, 2016 6:30 pm
by Morgan
try a different exhaust.............
Re: Cursed
Posted: Thu Jul 28, 2016 7:52 am
by DigDug
I've never thought to remove the silencer when attempting to start a Lambretta. :shock:
Re: Cursed
Posted: Thu Jul 28, 2016 10:58 am
by Snails
holty wrote:is there something blocking the exhaust, maybe some packing material inside, can you blow through it easy ?
I dont think so. Once its running its fine and kicking out normal gases out the back
Re: Cursed
Posted: Thu Jul 28, 2016 11:01 am
by Snails
Monty wrote:Here we go again Ed
No odd noises or rattles - its a new pipe, carb and engine so its only run once I got the electrics/clutch/carb issues sorted and only after carrying out the procedure above.
How would you know if its spitting back alot? Could over tuning the exhaust outlet cause then, not that I think I have
Re: Cursed
Posted: Thu Jul 28, 2016 11:02 am
by Snails
DigDug wrote:I've never thought to remove the silencer when attempting to start a Lambretta. :shock:
ha ha yeah they never cease to amaze / frustrate
Re: Cursed
Posted: Thu Jul 28, 2016 11:03 am
by Snails
Morgan wrote:try a different exhaust.............
Good point, I will try my other box if it will fit with current downpipe.
Re: Cursed
Posted: Thu Jul 28, 2016 11:41 am
by EddieStone
Bet your neighbours are hoping you get it sorted soon
