Transmission oil one more time...
Posted: Mon Jul 25, 2016 12:15 am
by railfancwb
Currently running a 1980 Vespa P200e and need to change transmission oil. I have received a range of responses as to what I need. Most say that 30 weight engine oil and 90 weight transmission oil are the same viscosity. If that is true I suppose I could use the 30 weight two cycle oil I mix with gasoline. Is that a reasonable supposition?
Others say I need oil formulated especially for transmissions to GL4 - but not GL5 - specifications.
Spotted this at the local Walmart. Would it be satisfactory?
Re: Transmission oil one more time...
Posted: Mon Jul 25, 2016 6:49 am
by shocky
Ive no idea about the oil in your pic but I have used straight sae 30 in all my geared scooters for 30 years lambrettas vespas and lmls never had any noticeable problem with wear or clutch slip
Posted: Mon Jul 25, 2016 9:01 am
by EddieStone
I'd go for an automotive oil rather than a marine one. Marine gearboxes run at significantly lower temperatures and often have to deal with being mixed with water.
Posted: Mon Jul 25, 2016 9:44 am
by Nerdy Norm
Any SAE30 oil will do. Look in the garden tools section, it's the same oil used for lawnmowers. Plenty available on Amazon:
https://www.amazon.com/s/ref=nb_sb_noss ... =sae30+oil
