Carb issues??
Posted: Sat Jul 23, 2016 5:15 pm
by LI150
Sorry for not being the best at explaining myself but here is my problem.
I have a 200 engine with a 25mm dellorto and a AF clubman.
My problem is that the revs don't drop cleanly it revs on for a bit then settles down.
Whilst messing around with it I discovered it works perfectly with the choke on.
I have tried different pilot jets but still the same. Apart from that his it runs great.
Any ideas anyone.
Re: Carb issues??
Posted: Sat Jul 23, 2016 5:32 pm
by Daggs
Air leak? Incorrect setting of mixture screw? Pilot too lean? Combination of these?
Re: Carb issues??
Posted: Sat Jul 23, 2016 6:26 pm
by LI150
I have tried mixture screw and richer pilot so I am leaning towards air leak now
Re: Carb issues??
Posted: Sat Jul 23, 2016 9:19 pm
by Scooterdude
Trapped throttle cable. Well that's my guess.
Re: Carb issues??
Posted: Sun Jul 24, 2016 6:46 am
by LI150
I have checked this. Also if I put choke on it works as it should
Re: Carb issues??
Posted: Sun Jul 24, 2016 10:03 am
by LI150
Problem solved - loose exhaust nuts :D
