Exhaust advice needed...
Posted: Thu Jul 21, 2016 1:24 pm
Hi all,
It has been a while since I've looked through exhaust graphs to check out performance of some of recent year's offerings and hope that I might benefit from your experience/insight of pros/cons of the new options out there. I'm after a fast road use (perhaps even touring if there is enough low rpm power) pipe, rather than a pipe that can only perform whilst screaming at high rpm.
I'm looking at possible options for a reed 230 motor that is running 125 transfer and 183 exhaust durations (29 degrees of blowdown... please note that I'm after exhaust advice for these timings, rather than any comment on the barrel's porting), which should give an rpm/power peak of approx. 8500 rpm (8-9) so I'd like to find a pipe that services this peak but does not do so by sacrificing too much low rpm power... nor limit rev on too much! OK, I understand that this is looking for the holy grail of pipes and an unrealistic spread of power throughout the entire range, however, better to have high aspirations
Variable ignition timing will claw back some low rpm power and keep things cool at higher rpm but the pipe graphs that I've looked at show the typical delivery of power at one end of the rpm range or the other, with very few doing much of both. Without chopping an exhaust up to introduce a variable tuned length, as shown to work so well by one sprinter in recent years, what are my options?
I've had a quick look at some dyno graphs available online, however, they all tend to lead in direction of specific products, rather than give an objective comparison across the range. Scootering's previous pipe comparisons for Honda 205 and TS1 were fantastic but these are now somewhat out of date, with access to dynos meaning that lots of new pipes have been developed since.
So... what do you know?
Thanks in advance.
Adam
Thanks in advance.
Adam
