MB Taffspeed Inboard Disc Conversion Slave
Posted: Fri Jul 15, 2016 12:10 pm
by Innocenti225
Hi anyone out there with any info on the threaded Slave Cylinder used in these conversions? I have had to cut the original one out as it was seized in after sitting Idle for 20 plus years. The one I cut out have both the in valve and bleed valve on the face, but any clues at all to a replacement would be much appreciated...
Re: MB Taffspeed Inboard Disc Conversion Slave
Posted: Fri Jul 15, 2016 2:47 pm
by psychedelicropcircle
Mb would do you another if you sent your back plate.
Posted: Fri Jul 15, 2016 3:02 pm
by Innocenti225
Thanks..... the Back Plate is Fine I just need the info for the slave
Posted: Fri Jul 15, 2016 8:05 pm
by rosscla
The slaves would be custom made - it's not an off the shelf item - the pistons are from a mini or metro four pot caliper and are readily available as are the seal kits.
Posted: Sun Jul 17, 2016 7:02 pm
by Innocenti225
rosscla wrote:The slaves would be custom made - it's not an off the shelf item - the pistons are from a mini or metro four pot caliper and are readily available as are the seal kits.
Cheers spoke to Taffy at Lyden Hill yesterday and he brought me up to date...Cheers
