Multimeter help
Posted: Fri Jul 08, 2016 6:16 pm
by weedodger
Hi, is there anything on here to help teach a complete novice on electrics , and reading and problem solving with a multimeter, ? Electrics is the only thing I'm stuck with on a lammy, even setting up a multimeter is too much, I'd love to learn it, but would benefit from a simple, easy to understand tutorial, sticky, or someone with time and a good written down piece and pics
Re: Multimeter help
Posted: Fri Jul 08, 2016 6:38 pm
by Lamaddict
Try YouTube
Re: Multimeter help
Posted: Mon Jul 11, 2016 8:59 pm
by Grumpy225
What he said
https://www.youtube.com/watch?v=bF3OyQ3HwfU
Also read up on OHM's Law
Re: Multimeter help
Posted: Sun Jul 24, 2016 3:59 pm
by weedodger
Here's my scooters problem....battery, wassel unit set up....battery fine...when I switch on ignition...1st ,2nd and 3rd click of the switch......horn used to work...loud,and lights would go on also.without scooter being fired up.......not now.....lights and horn etc ONLY work when scooter is fired up..battery is 14 v or there a outs....any ideas where I should start to look .?
Re: Multimeter help
Posted: Sun Jul 24, 2016 5:47 pm
by Muppet
battery=how many amp?
Re: Multimeter help
Posted: Mon Jul 25, 2016 1:02 am
by rosscla
Depending on how you have it wired you can basically have AC to the loom when the battery is disconnected. On mine I have a battery isolator which breaks the battery out of the circuit. I wouldn't run it like that for long though as I suspect that might cause issues with the regulator.
Check your battery connections / earth.
