Page 1 of 2
Which pipe??
Posted: Fri Jul 08, 2016 9:00 am
by Scooterdude
I'm running an iron 175 barrel clubman exhaust and remade Scootopia sh2/22 carb, runs well and I know they say if it ain't broke don't fix it but I'm after a bit more zip and was thinking of fitting an expansion pipe.
As I really want to keep most of the mid range and am not to worried about out and out top end the pipes that appeal are the JL3 and ADS3, is there much difference between the two? Or for whatever reason because of my set up would I be better off fitting something different?
Economy is important to me as well and I know an expansion pipe will reduce this but which pipes are best in this respect?
Cheers guys.
Re: Which pipe??
Posted: Fri Jul 08, 2016 3:06 pm
by a.j
BGM Clubman for the standard look, or Taffspeed copy. Priced sensibly,.Both will get you pulling well through the gears, provided your gearing is set up right.
I've learned a lot off here.
Re: Which pipe??
Posted: Fri Jul 08, 2016 4:09 pm
by Burnside
Surely what an expansion pipe will give you over a clubman is more top end, if you are not worried about it and economy is important I'm struggling to understand why you would want to change. Maybe consider changing your gearing instead?
Re: Which pipe??
Posted: Fri Jul 08, 2016 6:29 pm
by Lamaddict
I'd just leave it. I've an AF 175 kit and it runs very well on a SIL (economy) Clubman and 20 Dellorto, putting bigger stuff on might well mess it up.
Re: Which pipe??
Posted: Fri Jul 08, 2016 7:47 pm
by Scooterdude
You know what Lamaddict? I'm inclined to agree with you...
Re: Which pipe??
Posted: Fri Jul 08, 2016 9:48 pm
by Bufficus
Scooterdude wrote:I
Cheers guys.
Recently fitted a Robbospeed expansion to my TS1 255. Went down two atomisers from the Super Tourer I took off.
Re: Which pipe??
Posted: Sun Jul 10, 2016 9:38 am
by Jazzy
A bit old school but have a look at a 80s fresco.
It gives clubman like performance but a little more of it.
It's smaller diameter might work better with the smaller cc.
Re: Which pipe??
Posted: Sun Jul 10, 2016 10:06 am
by Meds
For the £250 on a pipe you could upgrade to a gori 200 kit for an extra £25 and change the pipe at later date.
Cam lamp sell them both, they might be able to help.
Re: Which pipe??
Posted: Tue Jul 12, 2016 11:37 pm
by scootcoot
Ancilotti ..best pipe ive used , gives good bottom mid and top
Re: Which pie??
Posted: Wed Jul 13, 2016 7:23 pm
by Knowledge
Chicken and mushroom. I always recommend chicken and mushroom. It is my favourite pie.
