Carb help needed!
Posted: Tue Jul 05, 2016 8:47 pm
Hi guys, just fitted a new Scootopia sh2/22 carb jetted as follows: 200 slide, 5899-2 atomiser, 120 main, 50 pilot and 50 starter, mixture screw 11/2 turns out.
I'm running a 175 iron barrel and Scootopia long cone clubman.
Although it runs very well and pulls well it just seems a bit blubbery just as I set off, am I right in thinking I should go down a big on the pilot jet or should I change the atomiser? Or just screw the mixture screw in a bit?
my other question is does the mixture screw control the mixture on the pilot only or the main jet as well ?
Cheers guys
Cheers guys
