Plastic drip tray.
Posted: Mon Jul 04, 2016 9:14 pm
by 10 inch Terror
Hi all, I'm after the best way to fit a new splash / drip tray on a standard petrol tank. Any hints / tips very much appreciated. Thank you in advance Pete.
Re: Plastic drip tray.
Posted: Mon Jul 04, 2016 9:21 pm
by bristolmod
stick it in very hot water then place on neck of tank, AFTER putting felt ring on.
Posted: Mon Jul 04, 2016 9:22 pm
by challenger
Warm it up and push it in from the Top of the frame loop. Its a bit tight but it will bend and spring back into shape after you get it through the hole,
Posted: Mon Jul 04, 2016 9:34 pm
by 10 inch Terror
Cheers fellas. Hot water it is then.
Posted: Tue Jul 05, 2016 10:45 am
by HxPaul
Once mine is fitted I then put the felt ring on top,that way it stops dribbles of fuel and can be taken out and dried (I just squeeze mine dry and re-fit).Some drip trays are made of hard plastic and no matter how hot the water is,it wont soften.I got one of these off Ebay and had to replace it.
Posted: Tue Jul 05, 2016 5:24 pm
by hendy
Can't remember where I got mine but it's made by atomic. It's white plastic and like hxpaul says there's no way to get it on with hot water. I hacked so much plastic out of it that I reckon I've halved it's weight!
Posted: Tue Jul 05, 2016 5:59 pm
by 10 inch Terror
It's a Scootopia one, so hopefully will fit ok.....
Posted: Tue Jul 05, 2016 8:29 pm
by garry inglis
must be close to finished if your fitting drip trays 10 inch :o
Posted: Tue Jul 05, 2016 8:30 pm
by Scooterdude
Yes I bought one from Scootopia, just couldn't get it to go in at all...... Until it came time to fit the floor rubbers in the alloy channels which I had to boil before I could get um in, anyway that prompted me to boil the drip tray which then went in no problem.
Posted: Tue Jul 05, 2016 8:47 pm
by 10 inch Terror
garry inglis wrote:must be close to finished if your fitting drip trays 10 inch :o
Just the legshields and rear runners to paint now. I'll post some more pics soon.
