MB Wiring Loom Help
tippo88
I'm wiring my Li AC only using an MB universal loom and following the MB diagram as per attached but I seem to have some extra wires.
There is an orange wire in the headset and also at the rear junction box area (over the outrigger in the photo) which doesn't appear to be on the schematic.
There is also an extra red wire in the junction box area. (in my hand in photo) The schematic shows two red cables that are not used in this configuration but I seem to have three.
Based on the schematic I can't see what purpose these additional wires have so I can just tape the up but I would like to me sure I'm not being dumb and missing something.
Cheers
Tippo
Sent from my SM-J500G using Tapatalk
DigDug
If everything works then just tape them up.
Did you have to do that?
10 inch Terror
Xbox live gamer tag: No.
I'm sure some are spares to run extra 'gadgets' as said tape them and leave them.
Scooterdude
Best thing to do as your not using a battery is to find the feed wire from the rectifier and attach the live from a battery charger then attach the earth wire to the frame and try everything just to make sure your not missed anything.
tippo88
Thanks guys. Like the battery charger idea will give that a go so can be sure all works before the engine goes back in.
