Fat Mamba
Posted: Mon Jun 29, 2009 8:23 am
Hello,
I have a Fat Mamba on my RB22. And yes the end can did crack and fall off. This was welded up by PM and returned to me under warranty.
However, the pipe now works it's way loose. First at the bracket end which I solved by double bolting and nylocking. Then the exhaust managed to pull out one of the large engine studs stripping the thread grrrrrrrr.
Coming home from the Shed in Peterborough I used a bungy to pull the tailcan up and stop the exhaust stripping the second engine stud. This worked a treat so I think I need to get one of Scooter Loopy John's end can supports.
Has anyone used one of these supports on a Fat Mamba and was it easy to fit?
Cheers.
Cheers.
