Remade li150 gears
Posted: Mon Jun 20, 2016 4:49 pm
by LI150
Are these any good. I no there made in India so slightly concerned about quality. I plan on possibly using them with a Gt186 kit.
Re: Remade li150 gears
Posted: Mon Jun 20, 2016 5:18 pm
by holty
im pretty sure the sill ones are strong enough, i had a sil 200 gearbox in my rb250 for a while, no problems, only changed it for a close ratio,
holty
Posted: Mon Jun 20, 2016 5:25 pm
by Padge
I've used one in my brothers 193 that I built, he rags the nads off it everywhere and not had an issue with it
I plan on trying one in my TS1 230 i'm building
Posted: Mon Jun 20, 2016 9:11 pm
by Tractorman
I must have got a bad set. First problem was second gear would not fit on the layshaft when I got it changed and the box assembled it was unbelievably noisy so I took the lot back and put the 125 gear set back in'
Posted: Mon Jun 20, 2016 10:08 pm
by 10 inch Terror
I don't think these 150 boxes are made by SIL. I've heard of shimming and fitment issues with them. I'd try and source an original Italian one if I were you.
Posted: Tue Jun 21, 2016 5:52 am
by LI150
Thank for replies. I have made my mind up I am not going to get one. Now to find an Italian one
Posted: Tue Jun 21, 2016 10:19 am
by HxPaul
Tractorman wrote:I must have got a bad set. First problem was second gear would not fit on the layshaft when I got it changed and the box assembled it was unbelievably noisy so I took the lot back and put the 125 gear set back in'
I fitted one and it was very noisy,I also had to run the cluster without a shim,with the shim fitted it locked solid.
