Headset Gear change shims
Posted: Sat Jun 18, 2016 11:12 am
by tippo88
I'm fitting a new gear change which I bought from beedspeed. It's a good fit on the handlebar but neither the large bush (a brass MB one) nor the thin L shaped one fit into the gear change casting.
I was reading on the Scootrs site that their gear changes don't need the bushings as they are made to better spec than the originals.
Am wondering if the beedspeed unit I have is designed to run without shims or whether I need to take the dremel to gear change casting to make the L shaped one fit in the gear change casting and to the large brass to make that fit?
Thanks
Tippo
Sent from my SM-J500G using Tapatalk
Re: Headset Gear change shims
Posted: Mon Jun 20, 2016 6:51 am
by tippo88
Bump
Posted: Mon Jun 20, 2016 7:27 am
by DigDug
A picture would help - I don't understand what "bushes" you are referring to.
Posted: Mon Jun 20, 2016 9:46 am
by Daggs
I'll try and help 'Tippo'
In recent months I have used two remade gearchange units. Like you I found the large nylon bush wouldn't fit. After some headscratching i decided it wasn't required in a re-made, probably far-east, part. So in both cases I fitted them without the large nylon bush. They feel perfectly O/K and work fine.
In both cases the thin 'L' shaped shim fitted fine without any fettling.
Posted: Mon Jun 20, 2016 11:27 am
by tippo88
Thanks Daggs. On mine neither the larger in my case brass bush fits nor the smaller L shaped one. Maybe I'll make the L shaped one fit so it looks correct and forget about the large one. Image
Posted: Mon Jun 20, 2016 5:53 pm
by wack 63
I dremelled a rebate in a ScootRS 5 speed changer so I could fit the shim but there's no rebate for the large bush to be used. It works fine with no slop.
Posted: Mon Jun 20, 2016 6:23 pm
by DigDug
A picture paints a thousand words. 8-)
Posted: Tue Jun 21, 2016 9:29 am
by tippo88
Thanks all! I've cut a rebate for the shim and as I was at the machine shop today have had the brass bush cut down so it fits. Will see if works better with or without the bush.
Posted: Wed Jun 29, 2016 9:08 am
by Daggs
Interestingly (or perhaps not) I fitted one of these gear changes yesterday and contrary to my earlier comments This time the 'L' shaped shim wouldn't fit either. I fettled it to fit, didn't bother with the big bush and it works fine..........
