Page 1 of 2
stage 4 200 and a 60mm stroke!!!!!!!!!!!
Posted: Sun Jun 12, 2016 11:27 pm
by shamrockexpress
Is this a common set-up?????????mate has removed his ts1 its got a 60mm stroke can he put back his packer and put on the standard stage 4 200 sil set up,,,,,,,,,,,,,,,,,,,,would port timings squish be fine on the 60mm stroke?
thanx in advance
ps this is just a stop gap until his new GT200 kit arrives
Re: stage 4 200 and a 60mm stroke!!!!!!!!!!!
Posted: Sun Jun 12, 2016 11:48 pm
by Norrie Bodge
What thickness packer is it? 1 - 1.5mm ??
Your m8 not selling TS1 kit is he?
Posted: Sun Jun 12, 2016 11:51 pm
by Bofs
It'll work fine. A 1mm Base packer will cancel out the extra stroke. It would need assembled to check the squish though.
Sent from my D5803 using Tapatalk
Posted: Mon Jun 13, 2016 7:45 am
by Muppet
check transfer port height with packer
Posted: Wed Jun 15, 2016 11:31 am
by Special X
It would increase the transfer and exhaust timing by aprox 5/6 degrees.
Posted: Thu Jun 16, 2016 12:40 am
by shamrockexpress
So an expansion would work better than the clubman????????
Posted: Thu Jun 16, 2016 5:14 am
by drunkmunkey6969
Have we finished talking about the 60mm stroke and packer?????????????????????
Moved straight onto,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,exhausts!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
You are going to change the gearing ?!?!?!?!?!?!?!?!?!?!
Posted: Thu Jun 16, 2016 11:12 am
by Mag
Can I join in?????????????????????
Posted: Fri Jun 17, 2016 6:22 pm
by Muppet
check transfer heights with packer ask again; a adult mite reply
Posted: Fri Jun 17, 2016 7:34 pm
by shamrockexpress
Just passing the info onto a mate who asked my advice
what would i know, i,m an electrican
will let yous all know how he gets on, first things first renewing his AA membership
