Weird one!
Posted: Sat Jun 11, 2016 4:53 pm
Had a bogging problem on my P2 for a while and can't suss it out.Bought the disc engine complete and stripped it three times with new bearings and seals properly fitted with yamabond.No damage to the casings and no leak from behind stator.
Symptoms are when the scooters on its side stand or sat upright,it will bog when you blip the throttle,sometimes enough to make it stall.Lean the scooter over to the right and it will rev normally!
Cleaned out jets,
Tried new carb with new jets,
Mix screw makes no difference
New SIP fuel tap with new hose,
Cap off fuel tank,
Tried new plug,cap,HT lead,
Changed Cdi,
Tried another stator,
Changed floats,no kinks in fuel pipe which was shortened
Plenty of fuel getting to carb,good flow but only revs ok when leant over to the right
I've rebuilt a few PX engines but this one has got me beaten.Only thing I haven't tried is another flywheel.
Anyone have any ideas?
Cleaned out jets,
Cap off fuel tank,
Changed Cdi,
