Thinking of fitting a Scootopia 22mm carb
Posted: Fri Jun 10, 2016 8:27 am
by Scooterdude
Thinking of fitting one of the Scootopia 22 mm remade delortos, at present I'm using the standard SH1/18 on my 175 stage 4 with no other mods apart from a Scootopia long cone clubman pipe. I'm not expecting rediculous amounts of extra power just a bit more upper mid range and top end as the SH1/18 seems to run out of steam. Is the Scootopia one the way to go or would I be better off with something else? Also as I already have some 5mm jets will these fit the Scootopia carb? Thanks in advance.
Re: Thinking of fitting a Scootopia 22mm carb
Posted: Fri Jun 10, 2016 11:12 am
by Doom Patrol
Do it. I'm running one. I did have one minor niggle. The gasket on the float bowl leaked, but I replaced that and it goes like a good un. Not entirely sure how you would jet it for a 175 though.
Posted: Sat Jun 11, 2016 11:59 am
by philz
I'm just running in a 175 with a new 22mm Jetex. No problems so far.
Posted: Mon Jun 13, 2016 1:22 am
by Lamaddict
Old 20mm Dellorto's are a good carb. I've got one on a 175 kit with a SIL clubman. Main jet is 115.
