Front Hub - Clunking
- Doom Patrol
- registered user
- Main scooter: Jet 200
- Location: Second star on the right and straight on till morning
- Contact:
The locating pin in my front hub has a bit of play in it and doesn't sit tightly. It allows the backplate to move with an audible clunk when you're braking, which is probably not a good idea in the long run. Initial thoughts are that you might be able to sleeve the pin or something like that. I'd be interested to hear how other people have solved this problem.
- HxPaul
- registered user
- Main scooter: lambretta Li 150
- Contact:
This should help.
http://www.ilambretta.co.uk/forum/viewt ... hub#p48669
- Doom Patrol
- registered user
- Contact:
That helps, thanks. Seems like I was on the right track then.
- garry inglis
- registered user
- Main scooter: ts1 230 and rb200
- Contact:
ive got the same problem so a couple off good fixes there thanks
- Doom Patrol
- registered user
- Contact:
I think that's what I'm going to try. Mainly because I don't have access to any copper tubing. I've found some braided hosepipe which is the perfect size. Not sure how it will stand up to the job, but it's worth a try.
- essexgp
- registered user
- Main scooter: Indian Gp200 Indian Gp Cutdown
- Contact:
Lasted about 3 years on mine, I just put another piece on when it became wornDoom Patrol wrote:I think that's what I'm going to try. Mainly because I don't have access to any copper tubing. I've found some braided hosepipe which is the perfect size. Not sure how it will stand up to the job, but it's worth a try.
- garry inglis
- registered user
- Contact:
if you lift the floorboards near your bathroom you will find some 15mm copper
Scooterdude
- registered user
- Main scooter: Lambretta LI 125 S3
- Contact:
I to had this problem on my series 3, the original back plate was damaged so being new to scootering I dident know any better and bought an Indian GP one, it fitted but I had to file down the shoes to get em on but the locating pin flopped about like a cock in a stocking in the back plate, then I got an innocenti GP back plate, although there was a bit of movement it wasn't that bad and I was able to loose it by tightening up the inner spindle nuts.
From an engineering point of view fitting tape, hose pipe, copper pipe etc is just bad. Better to remove the link and build the peg up with weld then have it machined down to the correct diameter.
