Dyno Operators
Posted: Tue Jun 07, 2016 8:01 pm
by Markymark
Hi all,
Can anyone recommend a dyno operator in the midlands ideally closest to Hinckley Leicestershire?
Many thanks
Mark
Re: Dyno Operators
Posted: Tue Jun 07, 2016 8:47 pm
by Doom Patrol
Don't know if there are any over your way. I'm sure there must be. Readspeed does them around here.
Re: Dyno Operators
Posted: Tue Jun 07, 2016 9:10 pm
by Darrell Taylor
chalkie at replay scooters
Re: Dyno Operators
Posted: Tue Jun 07, 2016 9:14 pm
by Markymark
Thanks Darnell,
Hopefully could manage that distance without a seizure !
Re: Dyno Operators
Posted: Tue Jun 07, 2016 10:46 pm
by GTFOMWSC
Diablo nuneaton
Re: Dyno Operators
Posted: Wed Jun 08, 2016 7:11 am
by Markymark
Hi is Diablo still running his dyno as I thought I had seen on here he had retired?
Cheers mark
Re: Dyno Operators
Posted: Wed Jun 08, 2016 8:17 am
by Timbo
He does occasionally do it at weekends but it's not his full time job,
Re: Dyno Operators
Posted: Wed Jun 08, 2016 1:38 pm
by Burnside
Markymark wrote:Thanks Darnell,
If you are worried about that then you might want to consider doing some plug chops and getting your jetting in the right ballpark (or at least on the rich side) before sticking it on a Dyno
Re: Dyno Operators
Posted: Fri Jun 10, 2016 7:02 pm
by Markymark
Thanks timbo that's good to know!
Hi burnside,
Yes I have done but I'm at the paranoia stage of my jetting as its running to well!
Re: Dyno Operators
Posted: Sat Jun 11, 2016 10:37 am
by shocky
Doom Patrol wrote:Don't know if there are any over your way. I'm sure there must be. Readspeed does them around here.
a friend was quoted £300 to set up a vhsa 30mm by them dispite not needing a new carb as he had a 32tmx and keihin 35mm the cost of the new carb was extra
he also has a tendancy to remove all jet sizes from his set up rhymes with james hunt comes to mind
