Dyno Operators
Markymark
Main scooter: Lambretta Gp150
Hi all,
Can anyone recommend a dyno operator in the midlands ideally closest to Hinckley Leicestershire?
Many thanks
Mark
Don't know if there are any over your way. I'm sure there must be. Readspeed does them around here.
Darrell Taylor
Main scooter: LAMBRETTA
chalkie at replay scooters
Markymark
Thanks Darnell,
Hopefully could manage that distance without a seizure !
GTFOMWSC
Diablo nuneaton
the man don't give a f@@k
Markymark
Hi is Diablo still running his dyno as I thought I had seen on here he had retired?
Cheers mark
Timbo
He does occasionally do it at weekends but it's not his full time job,
Burnside
Main scooter: Lambretta TV200
Markymark wrote:Thanks Darnell,
If you are worried about that then you might want to consider doing some plug chops and getting your jetting in the right ballpark (or at least on the rich side) before sticking it on a Dyno
Markymark
Thanks timbo that's good to know!
Hi burnside,
Yes I have done but I'm at the paranoia stage of my jetting as its running to well!
Doom Patrol wrote:Don't know if there are any over your way. I'm sure there must be. Readspeed does them around here.
a friend was quoted £300 to set up a vhsa 30mm by them dispite not needing a new carb as he had a 32tmx and keihin 35mm the cost of the new carb was extra :o
he also has a tendancy to remove all jet sizes from his set up rhymes with james hunt comes to mind
    Users browsing this forum: No registered users and 54 guests
