Page 1 of 3
Does AF rayspeed really exist!?
Posted: Thu Jun 02, 2016 7:41 pm
by ridden not hidden
I need to order some parts for my Lambretta and because one part is AF specific (close ratio 1st gear) I have to use AF, after a few days of unanswered phone calls (at different times of the day) as I had heard you can only phone them on a smunday between the hours of eleventy and shinty six I am no further on. I don't suppose any other shop has the 1st gear I need (along with other parts I need) and they can have the couple of hundred quid in their till.
Re: Does AF rayspeed really exist!?
Posted: Thu Jun 02, 2016 7:59 pm
by 10 inch Terror
Try Andy Francis. He stocks their stuff and may be able to help.
Posted: Thu Jun 02, 2016 8:16 pm
by Doom Patrol
They're a figment of the imagination.
Posted: Thu Jun 02, 2016 11:39 pm
by philcasino1973
i,m in the same boat re a 36t 4th gear for the af box just cant get hold them been trying for 4 weeks now they dont even reply to e-mails
thinking of sending a carrier pigeon .........................................
phil
Posted: Fri Jun 03, 2016 7:10 am
by 10 inch Terror
Are these close ratio boxes made from cheese? Why are so many getting damaged?
Posted: Fri Jun 03, 2016 6:22 pm
10 inch Terror wrote:Are these close ratio boxes made from cheese? Why are so many getting damaged?
Mine was due to kickstart shaft piston failing but I have heard that they don't like high HP motors. If I can't get hold of AF I might end up putting a GP box in
Posted: Fri Jun 03, 2016 6:39 pm
by holty
these gearboxes are based on an indian 200 gearbox, originaly used a spanish loose 2nd gear and maybe li first gear,and standard sill 200 3rd and 4th gears, with a one off cluster, i think they are all indian construction now, ive had one in my rb250 for quite a few years, ive had a broken cluster, my fault i had clutch drag and should have fixed it, otherwise no problems, im sure how you ride and use the clutch and throttle will have an effect on how long they last, along with genral maintenance,
correct oil level in gearbox helps, magnetic oil drain bolt ,oil changes etc, my next project will be getting one of these gearboxes, i like them.
Posted: Fri Jun 03, 2016 6:56 pm
by Knowledge
ridden not hidden wrote:I need to order some parts for my Lambretta and because one part is AF specific (close ratio 1st gear) I have to use AF, after a few days of unanswered phone calls (at different times of the day) as I had heard you can only phone them on a smunday between the hours of eleventy and shinty six I am no further on. I don't suppose any other shop has the 1st gear I need (along with other parts I need) and they can have the couple of hundred quid in their till.
Perhaps you should try their on-line shop?
Oh, they haven't got one of those either. Perhaps if they did, they would have more time to answer the phone?
Posted: Fri Jun 03, 2016 6:59 pm
by jonboy
I've always phoned between 5 and 6 pm
and always got an answer
Posted: Fri Jun 03, 2016 9:31 pm
by chippy
jonboy wrote:I've always phoned between 5 and 6 pm
Same here, don't ring often as I live nearish but called at different times and always got through
