Rally 200 drilling airbox
storkfoot
I have a standard Rally 200. The only difference from original is a SIP road exhaust and a 122 main (it may well be dropped to a 120).
I hear of people drilling holes in the airbox. To my eye, I can't see this making any material difference on my set up.
Any thoughts please?
cartmel808
I have same pipe & 120 main on mine with drilled filter... think from memory I drilled a 5 or 6mm hole in the heart shaped area on underside of filter (where it sits over the main jet)...
Norrie Bodge
Do as likes this piccy m8
storkfoot
Thanks for that. Will that allow me to run a very slightly bigger main jet?
Norrie Bodge
Probably, try it but do some plug chops m8
storkfoot
Cheers. I'll give it a go.
storkfoot
Finally got around to doing this. I must say it does work. More torque throughout the full throttle range.
paulnobodyimportant
Main scooter: varies
Next thing to do Paul, is put a Malossi 210 top end on. Plenty of torque right the way through the rev range :D :D
cgt75b
Main scooter: lambretta
Then whack a 60mm Pinasco crank in it :D
storkfoot
Still on the original '73 piston believe it or not. I did treat it to new rings before I went to Europe on it last year though !
