AF Cassette Clutch Question
Posted: Sat May 28, 2016 5:48 pm
by GeorgeS
Hello,
If I'm fitting an AF Cassette clutch (road one, fitting to a series 2 Li150 tree) do I need to purchase the brass bush or does it come with it already fitted?
Also, from the pictures it looks like it is supplied with a nut & washer, but is a tab wash also required? Looking to put a parts list together so I'd be grateful if you'd mention anything else I would need as part of the fitting.
Thanks,
George.
Re: AF Cassette Clutch Question
Posted: Sat May 28, 2016 7:17 pm
by 10 inch Terror
It comes complete with the brass bush. There is no tab washer you loctite the nut on with a spring washer.
Posted: Sat May 28, 2016 8:07 pm
by roadrunnerian
I have af road and race both good clutchs very light with a good nylon lined cable one thing do not use a dog leg lever use a standard lever, I did have a li side casing which I changed to a gp side casing due to problems with clutch action
