Page 1 of 2
End plate stud help required......
Posted: Fri May 27, 2016 6:50 pm
by alanscottj
I have just had some ally welding done on a casing and the welder has drilled and tapped new holes for the studs. He has done a fantastic job (aircraft welder
) but on one of the stud holes he has drilled and tapped it a couple of mm too deep, meaning that the stud goes in slightly too far not leaving a great deal of thread for a washer and nut.
Can I get a longer stud or is there any other option for me?
Also, do you guys use loctite on the studs?
Many thanks in advance
Re: End plate stud help required......
Posted: Fri May 27, 2016 7:05 pm
by HxPaul
Just put a couple of small washers in the hole and screw the stud up to them.
Posted: Fri May 27, 2016 7:06 pm
by alanscottj
HxPaul wrote:Just put a couple of small washers in the hole and screw the stud up to them.
That had crossed my mind actually
What about loctite?
Posted: Fri May 27, 2016 7:09 pm
by garry inglis
hxpaul nice one
Posted: Fri May 27, 2016 7:46 pm
by HxPaul
I always loctite all the engine studs in place.
Posted: Fri May 27, 2016 7:51 pm
by wack 63
Drop a ball bearing in.
Posted: Fri May 27, 2016 7:54 pm
by 10 inch Terror
Agree.
Posted: Fri May 27, 2016 8:38 pm
by a.lo.v2
in think MB do longer studs, or get some 7mm threaded bar or a bolt and cut it to length.
Posted: Fri May 27, 2016 8:40 pm
by a.lo.v2
or exhaust stud?
Posted: Fri May 27, 2016 8:57 pm
by alanscottj
Sorted! Nice one
Now, do I use flat washers or spring washers?
