Lambretta jetting help please! 175 Li
Posted: Wed May 25, 2016 10:26 am
Can anyone help with jetting my carb? Engine details are: Li150 with 175 Stage 4 cast iron barrel, using a Sh1/20 carb through the airbox. It has a GP style air scoop with no baffle in it. The exhaust is a KBR clubman style. Carb jetting is 45 pilot, 105 main, 50 choke, a 5899-6 atomiser and a 5914-2 slide.
When it's cold, I use the choke and it usually starts by the second kick. When it runs, it's a bit 4 stroky around quarter throttle, but past there it runs fine, plug is a nice colour and it pulls OK. I changed the atomiser from a 5899-2 to the 5899-6 and it cured a lot of the low rev 4 stroke it had. It 4 strokes all the time if I put a 108 main jet in.
When it's warm after being left for a bit it can be a right bu99er to start. If it doesn't fire up first or second kick, it will take about 20 or 30 kicks to get it going. By then there's a smell of fuel, there's some dribbling out of the carb rubber. When it starts, it sort of chugs to start with and I have to tease it to get it to run properly. If I open the throttle just a little at the wrong time, it will stall. Sometimes it will fire just once when I kick it but it will not run. It seems to me that it's far too rich and flooding. When it eventually does fire, it doesn't smoke at all - in fact it's pretty not smokey in general, unless the choke's on. I tried a 42 pilot, and it fired up easily when cold, but I took for a 5 mile ride and it was even harder to start. I checked the plug and it was dry. So I'm puzzled if it's too lean, or too rich.
Anyone any idea why it's so hard to start when it's warm? I've had this scoot as a standard 150 since 1990 and it was never a poor starter. I like the performance of the 175 as it's much more fun/safer to ride, but kicking it over 20 times to get it started is annoying me now!
I'm starting to wonder if there any chance the timing might be the problem? Squish is 1mm and the timing I can't remember exactly, but I've checked it many times with a strobe gun and it was OK. It's a 6V points system, but when I when I was setting it up I remember having to turn the stator plate to the limits of the slots to get it to time up statically. But it timed up with a strobe so I've assumed it's OK.
Cheers for any help on this.
