Page 1 of 2
Is this normal
Posted: Sat May 14, 2016 5:34 pm
by Rs fruitbat
I've got a little bit of oil on my exhaust .
I've had the cowling off today and can't see where it's coming from , I've checked with the engine running , head gasket , inlet and exhaust gasket look good , the only thing that has recently happened is the spark plug came loose , maybe it's just the excess oil finding its way onto the exhaust , scoot runs well no loss of power and the compression is very good , any ideas chaps ? Oh and it's my first lambretta .
Re: Is this normal
Posted: Sat May 14, 2016 6:45 pm
by hendy
No, it isn't normal.
I recently went through the same thing on my first lambretta. In the end it turned out to be a loose blanking plug in my cylinder head.
What cylinder kit is it?
Re: Is this normal
Posted: Sat May 14, 2016 9:02 pm
by Rs fruitbat
hendy wrote:No, it isn't normal.
It's just a standard engine
Re: Is this normal
Posted: Sat May 14, 2016 10:35 pm
by lambro
On a J, there isn't much to leak down there, but it has to be from somewhere, is there a hairline crack on the front pipe joining the box,
This is common and can be fixed by dropping and re-welding the joint.
Shaun.
Re: Is this normal
Posted: Sat May 14, 2016 10:37 pm
by Donnie
J range isn't it?
Id be looking at the base or exhaust gasket looking at the position of the oil
Re: Is this normal
Posted: Sat May 14, 2016 11:21 pm
by Rs fruitbat
lambro wrote:On a J, there isn't much to leak down there, but it has to be from somewhere, is there a hairline crack on the front pipe joining the box,
Shaun.
Thanks for all the replies , I've taken the exhaust off for a closer inspection and umm I think it's more than a hairline crack
Donnie wrote:J range isn't it?
I don't know how you both guessed it was a J range just from that one pic .
Re: Is this normal
Posted: Sun May 15, 2016 8:37 am
by Donnie
Engine mounts are unique to the j range
Re: Is this normal
Posted: Sun May 15, 2016 9:00 am
by Rs fruitbat
Donnie wrote:Engine mounts are unique to the j range
Thanks , being a lambretta newbie everyday is a school day
Re: Is this normal
Posted: Tue May 17, 2016 10:49 am
by corrado
Rs fruitbat wrote: , I've taken the exhaust off for a closer inspection and umm I think it's more than a hairline crack
There's a technical term for it ................................... it's fecked.
Re: Is this normal
Posted: Tue May 17, 2016 7:43 pm
by Rs fruitbat
corrado wrote:Rs fruitbat wrote: , I've taken the exhaust off for a closer inspection and umm I think it's more than a hairline crack
I'm going to have a go at welding it, I'll post some pics up when I've finished
