Scoot RS Dics brake
Posted: Wed May 11, 2016 9:26 pm
by Rick
Has anyone a parts diagrame for a Scoots RS dics I can't find one anywhere... My dics was stripped by the chap spaying it and we think there are a few parts missing
Re: Scoot RS Dics brake
Posted: Wed May 11, 2016 9:40 pm
by Doom Patrol
You might find an exploded diagram of the Italian one. Wouldn't they be the same?
Posted: Wed May 11, 2016 10:19 pm
by corrado
Inboard should be the same but Innocenti never made an outboard.
Posted: Wed May 11, 2016 11:40 pm
by Rick
Sorry it's an outboard hydrolic brake
Posted: Fri May 13, 2016 1:40 am
by corrado
Long spacer tube in centre of hub, bearing either side of that and seal either side of each bearing. Axle goes through the caliper mounting plate then through the speedo housing cover, then small spacer tube goes on axle then feed axle through the hub, insert top hat over axle on the nearside then thick nut goes on.
Posted: Sat May 14, 2016 3:57 pm
by bazza3004
Couldnt get mine on with the thick nut without levering link out. Swapped it for the standard half nut and alls good.
