Front hub nut??
Posted: Sun May 08, 2016 4:04 pm
by eadmr04
Just fitting a front hub and the castle nut lines up with the spindle hole one side but not the other. it also seems to sit a bit to hi and above the hole in the spindle. it has a large washer underneath it. Any ideas?? Thanks.
Re: Front hub nut??
Posted: Sun May 08, 2016 4:37 pm
by mick1
What's the history behind this ? New hub/rebuild with existing/new spindle/etc ?
The nut certainly looks to short to be effective, is it the correct nut ?
What type/model of scooter ?
The more information the better.......
*edit* it's not a 20mm hub on a 16mm axle is it ?
Re: Front hub nut??
Posted: Sun May 08, 2016 4:39 pm
by hungdog
Have you got the bearing in ?
Re: Front hub nut??
Posted: Sun May 08, 2016 6:34 pm
by gaz_powell
some models use a castellated nut on the front and some don't - depends what it is ?
assuming the assembly is correct behind, the nut you have is not correct - if you put a split pin through it will be useless.
it appears that you need a normal deep nut, a castellated cover and split pin.
Re: Front hub nut??
Posted: Tue May 10, 2016 6:19 pm
by eadmr04
I bought a complete set of forks including front hub and everything from India. It was fully assembled and have just got round to fitting the front hub?
Re: Front hub nut??
Posted: Tue May 10, 2016 7:06 pm
by eadmr04
gaz_powell wrote:some models use a castellated nut on the front and some don't - depends what it is ?
I think you might be right Gaz, seems to make sense. Didn't realise they did the castellated nut and also normal nut with a castellated cover.
Re: Front hub nut??
Posted: Tue May 17, 2016 7:06 pm
by eadmr04
As Gaz suggested, now all sorted. Thanks.
Re: Front hub nut??
Posted: Tue May 17, 2016 7:32 pm
by gaz_powell
glad your sorted !
