TS1 Reed Valve Screws - Size
Posted: Sat May 07, 2016 7:52 am
by paulnobodyimportant
My phillips head screws look like they have been loctited fully in and all I'm doing is rounding off the heads. I've a spare cage but no screws. Does anyone know the size so that in can order some. From looking at other forums, hex heads are recommended.
Re: TS1 Reed Valve Screws - Size
Posted: Mon May 09, 2016 9:08 pm
by wack 63
M3 x 0.5
Posted: Tue May 10, 2016 11:25 am
Thanks Wack 63. And in a separate eureka moment I came across these loose screws from a PC that I stripped. They are M3 and some are of the correct length, but they are stainless steel, rather than brass, but don't think that will be an issue.
Posted: Tue May 10, 2016 3:30 pm
by wack 63
Just make sure to put a dab of Loctite on them, then just gently nip up. Also check the heads allow the block to fully seat flat in the cylinder.
Posted: Tue May 17, 2016 10:17 pm
by corrado
paulnobodyimportant wrote: I came across these loose screws from a PC that I stripped.
It's not just me that does that then.
