Small end bearing conrod side float question.
Posted: Thu May 05, 2016 11:05 pm
by ArKaTxU
Hi.
I have this crank with this measures.
What do you think? Is ok to put in an engine?
Thanks!
(CLICK TO SEE BIGGER)
Re: Small end bearing conrod side float question.
Posted: Fri May 06, 2016 12:14 pm
by wack 63
There seems to be a lot of endfloat on the big end, 0.5 mm plus would be better but you can fit a 20 mm wide small end bearing.
