Which grease for bearings?
alanscottj
Having knackered my bearings in less than 1000 miles I realise that I may have used the wrong grease on the original build, I think I just used standard grease. I have managed to get this today from a car place and they reckon it will do the job, particularly on the Mag Side Bearing. What do you think?
Minority
Main scooter: Li230 S3
HTB (high temperature bearing) grease is what I look for on the label. Be nice if you could get the actual temp range for the product. 140C to 170c should be fine.
Tractorman
Minority wrote:HTB (high temperature bearing) grease is what I look for on the label. Be nice if you could get the actual temp range for the product. 140C to 170c should be fine.
+1 if it doesn't say high temp or give temp ranges then chances are it won't be, never been a big fan of comma products anyway, just my opinion of course.
alanscottj
I found the spec online and it's good for upto 150 c. Will have a look elsewhere this morning and see if I can find anything better.
barnsleybilly
Main scooter: Li200
The grease to get, used to be Castrol BNS but that's not available anymore so I personally use Silkolene RG2 but that'll be fine for Lambretta wheel and mag bearings.
alanscottj
Ended up going to Flintshire Scooter Centre, they gave me a latex glove full of the good stuff that they use all of the time on their builds :D
Engine rebuilt with new crank, bearings and seals, all torqued up as it should be (and greased properly!) Initial leak test showing no leaks. Not 100% sure I used the right sealent on gaskets though as there is so much differing opinions on the web. Ended up using Hylomar Blue, so we'll see after a few miles how it holds up, I'll have to be taking it steady anyway to run in the new parts.
Tractorman
Make a little hole in a finger and you can squirt the grease out :)
daniel whiteley
Main scooter: 125 special
i use the grease from here
http://www.extralube-zx1.com/
    Users browsing this forum: Amazon [Bot] and 5 guests
