Small end bearing conrod side float question.
ArKaTxU
Hi.
I have this crank with this measures.
What do you think? Is ok to put in an engine?
Thanks!
(CLICK TO SEE BIGGER)
wack 63
Main scooter: '71 GP TS1
There seems to be a lot of endfloat on the big end, 0.5 mm plus would be better but you can fit a 20 mm wide small end bearing.
