BGM stator problems
Posted: Wed May 04, 2016 10:35 am
Have a 2nd hand BGM stator have done a check on it red & white 112, green & white nothing , red & white nothing what would need replacing, or who could repair it for me.
The UK's No1 Lambretta & Vespa Scooter Forum.
https://www.scooterotica.org/forum/
Rally220 wrote:Anthony Tambs can sort that for you, I don't know if he's a member on here but he is on FB and frequents Lambretta Street Racers page, and others etc. He's an electronic guru, he also makes the Gamma Units, so contactable here:
http://www.gammatechnology.co.uk/rtse1000.html
Rather contradictory statements there but I assume you mean GREEN and white? That being the case it will probably need a new LT coil (about £23) but have a good check of the connections and the cable. Put the meter probe directly on the point where the green connects to the LT coil, if you then get a reading (close to 500 ohms for a BGM) the problem is in the cable but if you still get nothing and the soldered joint is good (also check the connection to earth) then it will be the coil.TS1-200 wrote:......have done a check on it red & white 112, ......... red & white nothing
As I understand it you cannot check a stator with a multi meter, you will need an oscilloscope for a correct reading otherwise you will get false results? Its all above my pay grade but makes sense when Anthony Tambs describes what he's checking with oscilloscope.coaster wrote:Rather contradictory statements there but I assume you mean GREEN and white? That being the case it will probably need a new LT coil (about £23) but have a good check of the connections and the cable. Put the meter probe directly on the point where the green connects to the LT coil, if you then get a reading (close to 500 ohms for a BGM) the problem is in the cable but if you still get nothing and the soldered joint is good (also check the connection to earth) then it will be the coil.TS1-200 wrote:......have done a check on it red & white 112, ......... red & white nothing
Changing the coil shouldn't be too challenging provided you are reasonably practical and can operate a soldering iron![]()
Colin
You can check the resistance (Ohm) values of the individual components and that should tell you if the parts are good. The only way to tell when the trigger (firing point) happens is with an O scope.Rally220 wrote:As I understand it you cannot check a stator with a multi meter, you will need an oscilloscope for a correct reading otherwise you will get false results? Its all above my pay grade but makes sense when Anthony Tambs describes what he's checking with oscilloscope.coaster wrote:Rather contradictory statements there but I assume you mean GREEN and white? That being the case it will probably need a new LT coil (about £23) but have a good check of the connections and the cable. Put the meter probe directly on the point where the green connects to the LT coil, if you then get a reading (close to 500 ohms for a BGM) the problem is in the cable but if you still get nothing and the soldered joint is good (also check the connection to earth) then it will be the coil.TS1-200 wrote:......have done a check on it red & white 112, ......... red & white nothing
Colin
lolRally220 wrote:As I understand it you cannot check a stator with a multi meter, you will need an oscilloscope for a correct reading otherwise you will get false results? Its all above my pay grade but makes sense when Anthony Tambs describes what he's checking with oscilloscope.coaster wrote:Rather contradictory statements there but I assume you mean GREEN and white? That being the case it will probably need a new LT coil (about £23) but have a good check of the connections and the cable. Put the meter probe directly on the point where the green connects to the LT coil, if you then get a reading (close to 500 ohms for a BGM) the problem is in the cable but if you still get nothing and the soldered joint is good (also check the connection to earth) then it will be the coil.TS1-200 wrote:......have done a check on it red & white 112, ......... red & white nothing
Colin
You can check the resistance (Ohm) values of the individual components and that should tell you if the parts are good. The only way to tell when the trigger (firing point) happens is with an O scope.[/quote]Grumpy225 wrote:As I understand it you cannot check a stator with a multi meter, you will need an oscilloscope for a correct reading otherwise you will get false results? Its all above my pay grade but makes sense when Anthony Tambs describes what he's checking with oscilloscope.
