endplate threadlock?
Posted: Mon May 02, 2016 1:15 pm
by paul d
I've taken the gearbox endplate out of my gp150 to reshim the gearbox. The nuts and studs are all good but I was wondering does anybody use threadlock or nyloc nuts as a safety precaution when assembling?
Re: endplate threadlock?
Posted: Mon May 02, 2016 2:00 pm
by HxPaul
I use spring washers and nuts without threadlock and torque to 10 to 12 LBS-FT.
Posted: Tue May 03, 2016 12:36 am
by paul d
Thanks HxPaul for the quick reply. This is the first time I've worked on a lambretta and I want to give it the best chance of working.
Posted: Tue May 03, 2016 7:17 am
by storkfoot
Use the correct NEW spring washers. Don't re-use the old ones, IMO. I had old ones come loose despite being torqued correctly.
Posted: Tue May 03, 2016 8:14 am
by eden
Use thread lock on the studs into the case but not on the nuts to the studs
Posted: Tue May 03, 2016 9:03 am
by HxPaul
eden wrote:Use thread lock on the studs into the case but not on the nuts to the studs
Good point,always use theadlock on studs into case,engine cover studs,endplate studs,cylinder barrel studs etc.
Posted: Tue May 03, 2016 11:35 pm
by paul d
Thanks eden and storkfoot for the help. Threadlock and new spring washers ready.
