Page 1 of 2
Rally 200 drilling airbox
Posted: Sun May 01, 2016 9:41 pm
by storkfoot
I have a standard Rally 200. The only difference from original is a SIP road exhaust and a 122 main (it may well be dropped to a 120).
I hear of people drilling holes in the airbox. To my eye, I can't see this making any material difference on my set up.
Any thoughts please?
Re: Rally 200 drilling airbox
Posted: Sun May 01, 2016 11:09 pm
by cartmel808
I have same pipe & 120 main on mine with drilled filter... think from memory I drilled a 5 or 6mm hole in the heart shaped area on underside of filter (where it sits over the main jet)...
Posted: Mon May 02, 2016 9:48 am
by Norrie Bodge
Do as likes this piccy m8
Posted: Mon May 02, 2016 10:48 am
by storkfoot
Thanks for that. Will that allow me to run a very slightly bigger main jet?
Posted: Mon May 02, 2016 3:26 pm
by Norrie Bodge
Probably, try it but do some plug chops m8
Posted: Mon May 02, 2016 6:06 pm
by storkfoot
Cheers. I'll give it a go.
Posted: Mon Aug 08, 2016 6:54 pm
by storkfoot
Finally got around to doing this. I must say it does work. More torque throughout the full throttle range.
Posted: Tue Aug 09, 2016 3:52 pm
by paulnobodyimportant
Next thing to do Paul, is put a Malossi 210 top end on. Plenty of torque right the way through the rev range :D :D
Posted: Tue Aug 09, 2016 5:46 pm
by cgt75b
Then whack a 60mm Pinasco crank in it :D
Posted: Tue Aug 09, 2016 8:44 pm
by storkfoot
Still on the original '73 piston believe it or not. I did treat it to new rings before I went to Europe on it last year though !
