Series 2 legshield gap.
sydduckett
Is there meant to be larger gap between thelegsheilds and front strut? I ask because im dry building an indian series 2 and with the whole lot tightened up i have a gap of about half an inch.i have tried 2sets of legsheilds with the same result. I have been told that there Re shaped rubbers for this but i havent come across these?
Ta sef
Ser 1/2 use thicker washers http://www.scooterrestorations.com/lamb ... 5mm-thick/ Try fitting longer bolts to pull the legshields down then fit the runners one at a time.
