Carb questions and possible swap
Posted: Thu Apr 28, 2016 9:00 pm
by Snails
hi
I've a dellorto phbh 26, I really want a 24mm carb though and I was hoping someone might be looking to swap but before i do so I'd like to understand the difference between phnh and phbl?
Sorry if I've broken the rules in terms of asking for a swap on the general board but as I have some other questions about the carbs so I hope that's ok, if not please move..
Re: Carb questions and possible swap
Posted: Thu Apr 28, 2016 9:47 pm
by YAMLAM
Phbh have a larger body size than the Phbl.
Pilot and main Jets are same size but the Phbl uses different slides , atomiser and needles .
Phbl is available in 20,22,24,25 and 26mm. 25mm being the most commonly used
Posted: Fri Apr 29, 2016 4:00 pm
by Snails
Ah thanks. I guess I really would like to swap mine 26 phbh for a 24 mm phbl then, I have a 25 mm phbl which is going on my lammy but the 24 is for my vespa and it would be better to be able to swap the various parts between the two as I have to jet both of them up
