li 150 or gp 200 ?
Posted: Sat Jun 27, 2009 7:35 am
by db67
hi, currently running an li 150 gearbox with 17x48 sprockets (4:80) on my ts 225 with a jl 3 pipe & i just wondered if there would be any advantage gained by fitting an indian gp 200 gearbox with 19x46 sprockets (4:84) ? thanks for any info. db
Re: li 150 or gp 200 ?
Posted: Sat Jun 27, 2009 10:40 pm
by drunkmunkey6969
The final drive ratio difference is marginal....if thats what you are thinking about? Both are close ratio, but the GP gives clutches an easy life with the use of 18 & 19 tooth front sprockets
If its just the final drive ratios you are thinking about.....i'd save yourself the chew, and just stick with the Li box...maybe try 16/47 (4.99) i run that on my racer....and it goes well.
Posted: Sat Jun 27, 2009 11:14 pm
by Funkspeed
I'll be keeping the GP200 'box on mine when I drop the TS1 in shortly....currently running a Rapido 225 and the 'box seems to suit that really well so hopefully will be just as good for the TS1.
